Hi
I have only had my Vaio laptop 2 weeks.
However, I cannot create recovery disks as when I try to create them, It says first I must oinstall the Vaio Care Recovery software.
When I attempt to run Vaio update, it shows the 'Vaio Care Recovery' as an automatic update, but when I try to update it, it says fails and says 'please wait and try again later'
I have waited and tried several times now to no avail.
Thanks
David
Hi Ant,
A manual download may work for both but in order to give you a link to the downloads we need the correct product number - VPCEH18SE is possibly the model number (chassis reference). Can you please check this in Vaio Control Center -> system information ->model name?
Rich
Hi Ant,
Assuming you are running the original Windows 7 operating system the links for manual downloads are as follows.
Vaio Care Recovery
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000321150_9606/VPCEH1S8E
Rescue data (x86) Update Programme
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000317149_9385/VPCEH1S8E
Hope that helps.
Rich
Hi Ant,
Yes it is very straight forward. To download tick the box “I have read the disclaimer and agree to the terms and conditions”and then click DOWNLOAD, make a note of where on your computer you download the files and then follow the instructions on the Sony Support download page.
Good luck.
Rich
Hi, I have a SVP1322A4E I am unable to automatic download the following updates:
1. VAIO care recovery
2. NFC connection utility
Get message:- Please wait a while and try again.
I have the same problem. My model is: VPCEH3C4E. I hope you could help me.
Hi Bodger101,
For the Vaio Care Recovery update try a direct download and install from the support site for your model.
http://www.sony.co.uk/support/en/content/cnt-dwnl/SVP1322A4E/list#os2
The NFC connection utility update does not seem to be available as a manual download.
Rich
