Hi
I have only had my Vaio laptop 2 weeks.
However, I cannot create recovery disks as when I try to create them, It says first I must oinstall the Vaio Care Recovery software.
When I attempt to run Vaio update, it shows the 'Vaio Care Recovery' as an automatic update, but when I try to update it, it says fails and says 'please wait and try again later'
I have waited and tried several times now to no avail.
Thanks
David
I have the same problem with downloading the same update (31.03.2014, 31947KB) on my new SVF1521J1E, Windows 8.1. This means I cannot prepare recovery disks.
When I attempt to run Vaio update, it shows the 'Vaio Care Recovery' as an automatic update, but when I try to update it, it says fails and says 'please wait and try again later' - Model VPCYB1S1E - Windows 7
Please help me!
Hi vanillaiceman,
There is a manual download available which should work.
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000321151_9610/VPCYB1S1E
Others posting in this thread should check the support site for their particular model.
Rich
Hi barrynb,
Here is the manual link for your model.
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000321308_9605/VPCCB4C5E
Rich
Hi kollikoukku,
Here is the link for your manual download.
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000321308_9605/VPCF12Z1E
Rich
@rich912 wrote:Hi kollikoukku,
Rich
Thank you Rich!
It says incorrect version and "Please use VAIO Care Recovery for Windows 7 64 bit version."
Hi kollikoukku,
Assuming that Windows 7 64 bit is the operating system you are using, did you extract the files from the .zip before running - you cannot run this without first extracting.
Rich
Thank you Rich.
I extracted the file to desktop.
But I still got the same error.
Hi kollikoukku,
So what operating system are you running. This is the second report of a similar problem but before reporting this to support we need as much information as possible.
Rich
