Can I upgrade my RX1 from 256mb to 512mb by removing all the memory from the slots, then inserting the two blanks and putting 2x 256mb into one bank?
Don't see any problems with that as long as you buy the correct type of memory.
Hi
I would like to know if the memory type is a PC800 RDRAM ?
Can I upgrade until 1Gb (256x4)
Thank you for reply
Maximum memory is 512mb and it is as you say, PC800 RDRAM
RDRAM is very expensive
About £150 when I last looked to take my RX1 to 512mb. Why did Sony have to use RDRAM?
Now the price is very low just because of the world crisis.
You know what I mean :smileyrolling_eyes:
I found 512 mb for 171 ¬uro.
The US Dollar is low.
It's the time to make business
But I hope the war won't be. :smileyrolling_eyes:
And don't forget that the RamBus profit from a band-width broader than DDR
PS:smileygrin:on't pay attention to mistakes
I've just upgrade the memory
And I finaly knew that users of the PCV-RX1 can upgrade the memory until 2 Gb .
It works
I have now 768 Gb (256+512 it's enough) :smileygrin:
Yes, that should be well enough Jazz :smileygrin:
