I have just purchased the PCV-RX402 VAIO computer can anyone tell me were I will get an online manual for it. It is not in the solution room at this site.
Thanks
Gary
There should be a CD-ROM that came with the literature pack, it's possibly blue in colour and slightly transparent.
Otherwise, try :arrow: www.vaio-link.com and enter your serial number. That should bring up a specialised section of the site designed for your computer.
By the way, you can find your serial number under VAIO System Information on the Start menu. If you're anything like me, then you'll hate turning the computer upside down/crawling round the back to look at the serial number
