I want to upgrade the RAM on my PCV-V1/G and wanted to know if I could put 2 1G cards in it? If so how do I do it? Where are the slots etc?
Hi adupuy,
The official specifications for your model indicate that the maximum amount of memory supported is 1024 MB, although Crucial.com are stating that 1024 MB per slot is supported (*Not to exceed manufacturer supported memory.) This is therefore somewhat confusing and I suggest that you either email or phone Crucial for confirmation before parting with your hard earned money...
I have been unable to find instructions for your model but I believe that the architecture of the PCV-V300/G is very similar. Click HERE for details.
Bear in mind that you could invalidate any guarantee by carrying out this procedure....
Hi I know its a long time ago but did you ever get a 2 gigabyte upgrade for your pcv-v1/g?
Thanks john
