I have frequently tried to download and install the new "VAIO Entertainment Platform Library Updater 64bit 1.0.0.12100". Every time I try to install it, the update goes half way and stops. Says that there was a problem and it couldn't be finnished and that I should restart my computer and try again. And every time it messes with my VAIO Media Plus and I have to remove it and reinstall it. Anyone got any solutions for this?
I am having exactly the same problem but I have not been able to find any solution.
Regards,
Miguel Angel
Good to know that I'm not alone with this, that means it's not just some random issue. I haven't figured it out yet either. I also tried to download it manually from VAIO's website, but the problem is same. I would REALLY appreciate and answere to this one.
What laptop and Windows are you using mitorre? I have VPC-F11Z1E and running Win 7 Home Premium with service pack 1.
I have a VPCEB1Z1E and I am still having the problem to install it to the date. Any news regarding the solution of the problem?
Regards,
Miguel
