Hello,
I bought a new HDD and I cloned it but now VAIO Recovery doesn't work. And I can't update or install the ATI driver. Please help.
Thank you
Is the new HDD exactly the same specification as the original HDD?
Vaio Recovery does not support the new advanced format (AF) drives which are formatted with 4K bytes per sector. Only drives with 512 bytes per sector are supported by recovery media.
Thank you. So I have to format my new HDD ? I have a WD Blue 1TB.
<Foreign language link removed by Community Manager>
