Hi, I want know why teh Memory Stick Icon in My PC is the icon of a object unknow. Th Memory Stick slot work rigth, but the icon It is not the appropriate one. Excuse my defective English. I need help. Thanks, Angel
Have you reassigned any drive letters so that the memory stick drive letter has changed?
Thank you for the response. Not, the icon show like that initially after installing the original controllers to him of sony. Format the computer and volvi to installing them, but initially already the icon appears this way. Excuses again by my English poor. I am Spanish and I thought that the English was the best form of communication. Thank you very much for your interest. A greeting, Angel
Check out this post:
POST
It may be as simple as SNYMSICO.DLL is missing from the Windows directory.
and look in Vaio Link for any updates for the memory stick reader, which may put this .DLL file there for you:
VAIO LINK
If you still want this file after trying the above contact me via "Contact Me" from my website (link below) and I will gladly email it to you.
And don't worry, your English is much better than my Spanish :smileygrin:
Contact me as I mentioned in my earlier post and I will email the SNYMSICO.DLL to you.
Put the file in C:WINDOWS and it may cure your problem.
Thaks William, you have a e-mail. A greeting,
Angel
William, thank you very much. The problem has been solved and the icon now is the correct one. Thank you and a cordial greeting,
Angel
I am very pleased that it was succesful and relatively simple to mend.
Thank you for taking the time to let us all know the successful outcome.
A cordial gretting to you too.
