Hey all, after my brother spilling dr pepper over my laptop i had the great fun of trying to get rid of the sticky keys finally sorted it but now the up key doesnt work at all so i need to get a replacement but my problem is i dont wanna send it off ive look but cant find where i can get a replacment? i can fit it my self no prob, does anyone kno where i can get one??? im in the uk
thanks
you could try these people http://www.clonesuk.com/npla.htm#key
they are in the uk. not sure if they do sony though. maybe worth you emailing them to find out. hope this was of some help.
thickloaf
Hi.
Pepper is not the "normal" liquid spillage. Have you tried compressed air to dislodge the particles of pepper?
I don't normally suggest removing keys but as the pepper is dust it may be worth rmoving the offending key to blow out the dust if all else fails.
You are so right:smileylaugh:
How stupid of me!
I am glad that I am not the only one that occasionally misinterprets a post:smileygrin:
I do it on a regular basis
