hi! i have a Vaio VGN-T2XP, an its got the intel 64MB Graphics card,(Intel® 82852/82855 Graphics Controller) its there any way i can upgrade the graphics card, enither by taking it to sony, or maybe a shop that'll do it indervidually? im thinking also of upgrading the RAM because i know that sony offcially supports this, is there any more hardware upgrades i can do?
Sadly I don't think you can upgrade the graphics chip
As for memory take a look at Crucial.com
The Graphics upgrade is a definate NO, the graphics chips are soldered to the Mobo.
The CPU upgrade will also probably be impossible as you have an Ultra Low Voltage CPU and if its the same as the TR Series (Its predescessor) it was also soldered to the Mobo.
The RAM Upgrade appears to be the only feasible solution, I would suggest Crucial.com for this. I have done the legwork for you, these are the compatible Micro Dimms:
CRUCIAL
wow thanks a lot guys. pity about the graphics card..
You're welcome orlyuk
