Hi friends,
After install Win XP Pro SP 2, I connect correctly with wifi router LINKSYS WRT54GS (I see connected in system tray, signal excellent....) but I cant ping any other PC and I can't navigate....
My vaio is: PCG-GRT916V
WiFi Adapter: LAN-Express miniPCI adapter 802.11g
Before SP2 all works correct, anyone can help me ???
Thanks all in advance !
Oscar
Disable the Windows XP Firewall and use an ordinary firewall instead.
Thanks for your response.
The windows firewall was disabled (after install SP2)...
Another suggestion... I'm crazy... Still connected but dont connect to any PC or Internet....
Other thing, with Ethernet (RJ45, wired) I navigate correctly, I see the LAN and Internet works perfect (with same VAIO and same Router WiFi)...
Thanks in advance !
My elkin card keeps dropping out at odd intevals which is a bit bizarre. Getting SP2 on here to see if it changes...
Hi Rich,
Thanks a lot for your effort, I try this !
See you soon,
Oscar
I hope that it sorts it for you Oscar.
Let us know how you get on.
