A very simple question!
What is the best way to clean the screen? At the moment I'm just dusting it carefully, but are there any recommended cleaning products or tips?
Many thanks.:smileyhappy:
I use a microfibre cloth which you can buy from any optician for a couple of euros... no water or anything else needed... even removed fatty fingerprints...
-- aioobe
Microfibre,Perfect.................
Thanks very muchfor replies!..Have microfibre cloth...Will use!!!:smileyhappy:
