Hi i have just brought a sony vaio fe11h and when it is running on batteries the cpu speed is 980mhz not 1.66ghz. i can't change the cpu control/speed under vaio power management as it is greyed out. please help!
Its meant to run at that speed when on batteries, its conserving battery power. Plug it into the mains to restore full CPU speed.
is there no way to make it run at full speed without plugging it into the mains.
I don't think it's possible on that model
Does it go into full speed when you play games?
It won't do anything at full CPU speed on batteries, thats the way Intel designed the chip.
Its only possible to run at full speed when plugged into the mains.
Yeah it's mainly built for long life office work on batteries
Thank you
