hi
can i update my award bios 1001 on my pcv-rx413n??? and where ?? thank u for helping me
Hello,
If an updated BIOS is available then it will be at www.vaio-link.com
You will need to register your computer if you haven't already done so.
Regards, Rob
If there are no major issues with your system, I wouldn't bother flashing the BIOS
"if it aint boken don't try to fix it"
