markuus
Visitor
bios update
hi
can i update my award bios 1001 on my pcv-rx413n??? and where ?? thank u for helping me :wink:
2 REPLIES 2
profile.country.en_GB.title
robpaxton
Explorer
Hello,
If an updated BIOS is available then it will be at www.vaio-link.com
You will need to register your computer if you haven't already done so.
Regards, Rob
kee-lo_
Member
If there are no major issues with your system, I wouldn't bother flashing the BIOS
"if it aint boken don't try to fix it"
