Hi all,
All of a sudden my Youtube videos stopped playing on my Sony Bravia TV. Till date I had no issues whatsoever. It logs on to my Youtube account and I am able to navigate through my playlists. But when I select a video to play it just displays as YOU TUBE on the screen and nothing happens. Videos on other sites like dailymotion are playing fine now.
What could be the problem here.
I had a problem with my Sony Bravia 40EX520 and it was very frustrating.
The youtube videos which used to play before, stopped playing suddenly.
Solution that might work is:
Select the youtube video -> options -> video playback quality -> change from HD - SD or viceverca and play again.. Hope it helps
I still have the youtube video loading issue please resolve it ASAP it’s not even a month i bought this TV and i’am facing such problems. If i would knew this earlier i would not have gone for sony bravia
Sony Bravia KLV-40W652D is not playing youtube videos. While i click on play button the video keeps on loading but doesn’t play. Please help me out fixing the issue.
Hi Asad.ali802,
I guess this model KLV-40W652D is not a European one. Maybe you can check with the community. I think you can check this issue in the US community, maybe they have a solution over there.
Cheers,
Almou_10
I am having the same problem with a brand new KD 49X8505B. Has your problem been resolved? If so, How?
Hi @miltonmac
Your TV has probably more in common with your phone that the OP's. Do the videos just keep buffering when using Youtube or do you get an error message?
Win_88
