Hi all,
All of a sudden my Youtube videos stopped playing on my Sony Bravia TV. Till date I had no issues whatsoever. It logs on to my Youtube account and I am able to navigate through my playlists. But when I select a video to play it just displays as YOU TUBE on the screen and nothing happens. Videos on other sites like dailymotion are playing fine now.
What could be the problem here.
Hi
There was a temporary fault affecting YouTube Videos loading on Bravia.
The fault has now been resolved and should not be problem anymore.
Happy viewing
Hola Srirams, me pasa lo mismo que a usted en España. También he preguntado en el foro español y todavía no sé qué pasa.
Seguiremos atentos a los expertos.
32 EX 500
________________--
Hello Srirams, there happens to me the same that to you in Spain. Also I have asked in the Spanish forum and I do not know yet what raisin.
We will follow attentive the experts.
Message was edited by: 89452072
I have the same problem with youtube on KDL 40EX713
Any ideas?
I have the same issue with my Sony Bravia, and also noticed that on PC for a few days now most youtube videos play no so smooth anoymore; I think it may be related to an update on youtube side that Sony didn't implement yet. Anyway, all other internet video services work, so it must be some API change on Youtube.
Problema solucionado. Ya funciona todo correctamente; fue un problema de Sony.
It is temporarily that You tube is not available, no panic. Try latter.
Regards
Damac
I am facing same problem on my Sony 40EX403 TV.
When this is likely to be resplved?
Thanks
I have the same problem on my KDL-32EX403 as well. Hopefully someone from Sony will read this soon and resolve the problem!
Hi
Happy viewing
Unbelievable! Youtube sometime is worknig, another time it is not. At the same time it is working through the regular browser and not working through the widget! I do not even have a clue how shall I configure the TV's network.
Disappointed - is this really a Sony?
KDL24ex320
Message was edited by: m-a-g16
