I have a sony kdl42w653a
how do I get the little attachment bits to put it on a wall? I have the silver stand but nothing to use to screw to the tv. It’s ridiculous that it doesn’t fit a universal wall mount bracket
Hi @Gheller Doesn’t the “VESA Mount Bracket Screw Bolt Adapter Kit for SONY Bravia LCD W6“ at £9.99 on Amazon help?
I have a universal wall bracket have no idea what I need as that doesn’t fit directly on to the tv. I’m useless so would literally need to be told exactly what to get. The think you mentioned is just screws and bolts?
Hi @Gheller If you have a look at the questions and reviews with images on Amazon it should give you a few ideas.
I have and I’m useless. I’m not sure if just these bolts and screws help with my universal wall bracket or I need the bolts and screws and something else. For a women it’s confusing haha
I was under the impression that you get fitting screws/bolts from the same place/brand/supplier as the one that provided the bracket in the first place? Especially that this model doesn't have VESA dimensions on the specifications page.
