I have had a Bravia KDL-40w2000 for some time but recently moved house and have decided to wall mount the TV. I have bought a universal bracket but was uncertain where to attach it to the TV and didn't want to risk damaging the TV using the wrong screw holes!! any help pointing me in the right direction would be greatly !!
thanks
Kent
Message was edited by: kentfermor
Hi, There are 4 bolt holes on the back of the tv, they look like they are in a square. As long as you bracket it vera compatible you'll be fine.
