We've just bought a KDL37EX723BU (37 inch LED tele). According to the manual, the TV should tilt on the supplied stand by up to 6 degrees. I can't get the TV to tilt.
Any suggestions? And what part does the tilting? The post? Or the clamp that attaches to the back of the TV?
Thanks in advance for any help.
im sure it tells you how in the manual, however as far as i recollect seeing, you have to remove a screw in the back where the tv joins the stand then tilt it back and re position the screw.
to be honest without looking i cannot be sure, i suggest you check the manual and have a look at the rear of the set, the answer lies there somewhere.
I did read the manual before posting a message and all I can see is a simple drawing of a TV and two arms - the hand from one arm is pushing the top of the set back whilst the hand from the other arm holds the base.
