x
Streeming rental films
profile.country.sv_SE.title
duffan
Visitor
KDL-40NX800, PC and IMAC WPA wireless lAN in operation.
Q. To rent films, I need a Browser with Adobe flash or MS Silverlight. or
--A connection between 1/IMAC and or 2/PC Vista and my HDTV.
Since WIFI why cant I connect to view the films on the HDTV or please explain how to.
I heard that Apple is releasing a new Apple TV which might do the job or do you know other meda items which can do the job.
Tried to register at Bravia.Internet.Sony.TV, but the code retrieved from HDTV didnot work. Why?
Please advice
1 REPLY 1
profile.country.en_GB.title
slowtrain
Visitor
Hi duffan
Install mezzmo on your pc and you can play all your media via the ethernet port.
http://www.conceiva.com/products/mezzmo/default.asp
A moderator will have to help you out in registering your TV.
