Sony KDL42W653a Apps Issue
profile.country.GB.title
msansom123
Explorer
I know this is an old problem (for me and on here!) but I have tried every solution posted here and elsewhere to try to access the apps through this TV. Nothing works!
Is there a possible hardware problem?
Other Samusung TVs connect perfectly via wifi!
Any advice different to all the other posts on here!
Thanks
1 REPLY 1
The_Black_Rose
Specialist
Hi msansom123,
Could you specify which app exactly are you facing an issue with? What happens when you try to access the apps?
Cheers,
The_Black_Rose
