I have had this TV for about 2 months now, and successfully managed to format a USB stick and record some programmes onto it from the TV. After recording I checked that the programmes were there but did not watch in full. I then removed the USB stick from the TV.
Now when I try to watch the recorded programmes I have one of two problems - either the USB stick is not recognised and says it needs formatting, or the TV does not recognise that the USB stick is inserted at all.
Any ideas on how to solve this so that I can watch the recorded programmes would be gratefully received.
Many thanks.
Hi Jenny, welcome to the Community
Have a look at this thread, which explains a little about ideal formatting and file types, and let us know if there's anything that helps.
Mick
Hi Jenny,
I will pass this on to the team to look into and update this thread with any suggestions.
Thanks,
Pascale
Hi jennyellis,
There are a couple of things that come to mind regarding this such as whether the TV 's firmware is up to date (you can check this using the below link:)
https://www.sony.co.uk/electronics/support/lcd-tvs-we75x_w75xe-series/kdl-43we753/downloads/00015058
Also, have you tried a different USB stick with the TV? I know that Sony recommends using a dedicated external HDD for this in the first place, maybe this has something to do with it.
Hope this helps.
Win_88
