Sony KD -65XE7093
Hi I turned on yesterday and started smoking from the back of the tv,
I have turned it off now
as anyone had this issue
seen a lot about 2007 to 2008 sony tv smoking
Although out of warranty would this be something Sony would repair
thanks for any replies
Hi @oriongi and welcome to the Community
The best thing to do is to contact Support straight away.
The problem with repair and cost of repair is it depends on exactly what has caused
the smoke and also what damage may have been caused internally from the heat causing the smoke.
Here's a direct number for Support: 0207 365 2810,
or here's a link for other contact options including live chat or email.
Let us know what they say
Thank You for the reply I will contact them,
