I bought this TV in 2020 and all built-in players such as all4, iPlayer etc don't load and simply report that something went wrong. I've reset it, updated firmware etc but nothing works. Any suggestions are very welcome.
Hey, can you try and clear cached data on your TV by pressing Home - Settings - Device Preferences - Storage - Internal Shared Storage - Cached data - Clear
Can you try and disable and then enable youview on your TV and try again. I hope this helps
it did work but has stopped working again.
This consistent problem is not what I expect of Sony.
There must be a permanent fix.
