Hi - Can anyone help with an older LCD Bravia (KDL-32S5500). When I re-tune (Auto) to get the digital channels stored they seem to be allocated to the wrong digital numbers. ITV turns up on digital channel 822 - What? Surely it should be listed straight after the BBC channels?
Hi iawhipp,
Welcome to the community.
I'll see if I can track down an answer for you. Which model TV do you have?
Thanks,
Pascale
When retuning don't attach the aereal until the tv as got to 20% or higher that should work I have to do that your tv should be right then if they are still mixed try 42%
Hi there,
Can you check if your TV is in the correct region for your area.
Please try re-tuning the TV and select your current region.
Let me know how you get on?
Thanks,
Sean Mc
