Hi all, Bought a Sony Bravia W82B, I cant find the internet Browser option? Im connected to wifi. Any ideas... tried Apps, All Apps, the centre round button on the control does not bring up a menu as it says in the manual. Any ideas what im doing wrong 😞
Hi there
The web browser will be there, under the Apps or All Apps. The icon is in blue and is labled "WWW" - Scroll through, and it should be right near the end.
Example below:
Hi there
Example below:
I have my new bravia, and i dont have any browser apps anywhere 😞
can you help me to have it? where to download it?
May thanks!!!
Got the same probem as you i cant find app like INTERNET BROWSER in Opera TV Store
@Duksa97 - if you can post the model of the tv, ill find out where it should be. The answer in this thread was for 2014 Smart TV models.
My model is BRAVIA KDL-48W705C and I can't find my browser aswell.
The internet browser is one of the latest app shown in the all app list, you have to go through the list...
