My Sony TV KDL-22EX553 came without the two screws needed to fix the stand.
Please advise what type of screws are required .
Maybe Sony should send them to me as they were not in the original box.
they were most certainly there somewhere in all that packaging and its most likely you missed them, however i suggest you contact your dealer first as he or she may very well have some spares lying around to get you out of trouble.
