I have a expensive stand which my current Sony tv is attached to via vesa mount and wouldn't want to change it. Can the KDL46HX853 be mounted this way or is the 6 degree angle critical for picture quality?
Thanks David
Hi David,
Welcome to Questions & Answers..:smileyhappy:
According to the User Guide Sony the HX853 can be wall mounted & Sony recommend using the SU-WL500 Wall-Mount Bracket (sold separately)..
Further information can be found on page 25-27 of the user guide - KDL-HX853 user guide
Perfect, thanks for you help.
You're welcome tenfxx..
