hi,
my sony wega KDL32XBR950 isnt turning on, no picture or sound,
the standby light just keeps flashing,
i have opened the back of tv and see no immediate blown capicatators or fuse.
is there anywhere i should be looking to resolve the issue?
thanks
kevin
first and foremost never open up a tv, there are no user serviceable parts inside and apart from that may very well have invalidated any warranty you may have,
the red standby light blinking means (which you have already established) the set has developed a fault and will require a service technician to fix it.
