i could not connect my mac to my new sony HX923 wirlessly although i spend talking to a techical support advisor at sony for about 75 minutes, he assured me it can be done, and promised to call me back but unfortunately til after a week have not heard from him, can anyone help
i assume you want to browse photo's, music and video on your home network and you would need to set up a home network on your laptop, with windows 7 its easy but i know nothing of Apple Macs but im sure you will find it on yours, it should be under network and internet in the control panel.
It will be best to go on through the user guide,it will help you out
