Hi,can anyone help me please?just bought a new tv Sony KDL-50W655 and a Sony BDVE4100 home cinema system,i cannot for the life of me get the tv to play through the home cinema system,ive done the test tone and its fine,ive played music and films from a usb drive both fine but the tv will not play through the system.ive got the audio systen selected and still i sit here in silence,so once again can someone please help or advise on this.....thankyou
Try turning everything OFF from the powerpoint on the wall. Leave for 2 mins and switch it back on again.
Did you check the Control for HDMI settings on the E4100 and the ARC settings?
Failing that, do you have another HDMI cable that you can test with?
Hi there
Ensure that you have done the following:
a yes to all of those suggestions apart from bravia sync on television,im not 100% sure i have done this correctly,how would i do this?
Hi there
For the E4100 - See page 50 of the manual : HERE - also on the same page see the section about "Audio Return Channel" and ensure its set to AUTO (which it should be)
For the TV - See instructions : HERE with vatious options, as well as HERE to see if it the TV detects the HDMI signal
ive gone to the bravia sync device list...selected Enable and it says " no hdmi or mhl devices found.pleasr check the connections
well that worked!.....turned it off for a few minutes and everything is now working
im so happy A Big Thankyou very much for all your help and patience,much appreciated
EXCELLENT !!
I was nearly out of idea's too
just one more thing...do i have to change any settings to play my PS3 and PS4 with surround sound?
Shouldnt do to be honest. However, what you can do, is check the audio output settings on the PS3 and ensure that ticks are placed against many of the 5.1 options (and DTS etc)
For PS3, see:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
PS4 - no need to change a thing (I think)
