hi..
I haved problem after update my XSP last knight. and this morning I dont know why... my phone wont boot. my phone always loop back to booting and never succes, always stuck in animation boot screen. soory for bad english I am from indonesia. thx
hello brother i got the same problem!what app did u remove and not compatible with xperia sp?please respond fast i repaired my phone twice but i still hve same problem like yours..thanks in advance!!
But how did you remove that application if you can't boot your phone? Which application was that by the way? I'm having the same problem.
Help me please.
Hi ..., mine was like two times restarted it self. After an update.
Not sure what the problem is,,,
I wonder if i reset it to factory again will it still the 4.3? Coz i want to try reinstalling the update again.
Thanks...
