Yes,it is the problem.You are welcome.
I have the same problem, but with no "smartkey app" installed !!
Then I got it from Google Play market, installed and uninstalled it, restarted the phone & factory reset - for other issues of course
- but still the same.
any ideas ? also removed "lockscreen" app data and forced close..
