Hi Just upgraded to ICS and at the cosmic flow was working normally but the screen movement from side to side was laggy. I restarted the phone and now the lag has gone but the cosmic flow well doesnt flow any more it is displayed just like the static wallpaper?
On the plus side I think the yellow/green issue seem better in my eyes anyhow!
I think this is an easy question. You should hold the screen until "add and personalise"thing pops out. Then, open Theme and choose your colour. Then, go back and do the same thing add and personalise and press wallpapers. And then, press live wallpapers and choose cosmic flow and it will start flowing again.
Cosmic flow animated was removed after the ICS upgrade. This also affected the xperia S and so on.
Rumours put it that it was removed as it eats up plenty of battery life. Cheers!
Remember to mark it correct or useful if the response deemed as what is it.
Thanks to Samson, got it going again. Had to select theme but also had to go to live wallpapers and select cosmic flow there as well and it flows again exactly as you said. Cheers
