Hi All,
Can someone please upload the powersaver.apk for Xperia Ray ICS as I accidentally uninstalled it?
Thanks.
Regards,
do not ask or download applications if you are not 101% secure it's a trusted source.
for answering your question it's much better to download any file manager from google play, then navigate to /etc/product/applications and install powersavemode.apk
Thanks a lot. Managed to install it from the path you specified. I had no idea I could find the apk there.
Thanks again and regards.
