Hi, everybody.
I cannot update my phone,or do anything (like transfering, repair) with PC Companion!
Always shows like, "try again later, the application is not installed"
i try again every way, and i write what happend. thx 4 ur help!
quite odd, install JAVA and restart your PC
everything i fine... i had to reinstall the whole system of mine phone. but now its ok:)
so it was your PC after all
