Hi, everybody.
I cannot update my phone,or do anything (like transfering, repair) with PC Companion!
Always shows like, "try again later, the application is not installed"
try SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
try SUS
Bridge (for Mac)
thx. i tried these, but nothing happend what solved my problem....:/
do you still get an error? if so, restart your PC > disable your firewall and antivirus > run again
which OS do you have?
i use win7, i tried everything: restart my PC, remove phone-and connect again... always error....
(i cant even repair my phone, or anything)
post a screenshot of the error
i dont think you will ióunderstand it becouse its Hungarian, but i try 2 translate well.
The application havent been installed well. Try again later.
There is another mess.: Cannot conect to the Server.
what about Sony Update Service (SUS)?
the same...
