On GB, in power menu there was an option to take screenshot. On ICS, power menu changed and there is no longer an option to take screenshot. Any suggestion?
Please search the forum before posting
Press and hold power button and volume down button exactly at the same time and hold them there until you take a screenshot
Sorry, I didnt used search as i m on forums regulary, I didnt noticed such posts
No problem
but the power button way was better, this one misses sometimes..
