Sorry for asking such a basic question but please confirm if I'm right on this.. The Sola basically has 3 memory divisions, the internal 8GB is approximately divided into 4GB "internal storage" and 4GB "phone memory", and the SD card we put in is given by "external memory" right?
Thanks
Yes, you are right
the internal storage reserved for mostly system and applications
the phone memory (internal SD) for your media (mp3. images)
and the SD (external SD) for additional memory to support your phone memory
this way the apps run faster because the memory is built in the phone
but sometimes causes problems like the PC detects the phone memory not the external SD
Yes, you are right
