i don't know if its because of ICS or something went wrong in my xperia s.
but in some games like Temple Run : Brave, Cut the Rope... or even when i open images... the screen start flickering.
does anyone have this issue?
and is it software related or hardware?
I just watched the first video, it seems odd, repair your phone with SUS and check if the flickering with the photo app continues
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
how does it flicker? can you record a video of the issue. do you have any taskiller, antivirus or battery apps?
well... its like the app freezed and restart at a point.. cuz in temple run i noticed its as it got suck and keep repeating the same frame... sometimes its slow.. and sometimes it flickers fast that u almost cant do anything other than pressing the home botton.
and i only activated macafe antivirus yesterday,
do u know any video recording app to use?
and thank you
it'll be easier to use another camera to record the issue, does it happen with other games or just with few games?
ok i will try to record nowthis mobile wasn't used since 2 months when it was purchased.
just started to use it few das ago.. and only installed the games today ( only these games till now)
but only noticed it in galary after i updated the software last night
if it's only one game most likely it's a compatibility issue
no its in two games till now... and in the galary app too..
i've just recorded two videos... i'll upload them once i copy them to laptop
here is the first video when i opened an image
ok we'll be waiting for them
and here is the second video at the game Cut The Rope
