i don't know if its because of ICS or something went wrong in my xperia s.
but in some games like Temple Run : Brave, Cut the Rope... or even when i open images... the screen start flickering.
does anyone have this issue?
and is it software related or hardware?
you should backup
Uliwooly screen still flashing to unlock the screen even I did the SUS..
Well, i'm not that expert, but maybe there is an app u've installed which makes this.. check if this happens after a factory reset.. if it doesnt, install ur apps one by one and each time check if this issue comes or not..
or u can try going back to the previous software version 2.3.7 (gingerbread)
I am also facing this problem. When the phone is locked mode its screen flash. then again black out. its happining frequently. I try to repare it. but still problem after update ICS
wel it started to happen again... cud it be because of ICS update?
i was thinking of finding a ginger bread rom and then to flash it back
you can try
How to manually update 2012 Xperias to android 4.0.4 build number 6.1.A.0.452
http://talk.sonymobile.com/thread/41609 (click on downgrade)
