Does Xperia V really have Scratch Resistant touchscreen?
One day I woke up I found my phone had scratches.
I don't remember when it happened, probably my key or coins scratched the touchscreen when they are in my pocket. But I'm sure I never put any sands into my pocket or going to beach with the phone.
At sony's site, it said it has 4.3 inch scratch-resistant TFT touchscreen. So how can this happened?
You only scratched the anti shatter film not the screen. Can you see there is a film called ASF on the surface of the display?
duh, why they have to put scratch-friendly sheet on scratch-resistant screen? This will only mislead consumers. No wonder the screen easily attracts fingerprint.
Thanks for the info.
