I had 25% of battery life remaining and stamina mode was showing 7 hours
Now even after charging at 100 % stamina mode is not showing new time
Check the screen shot
1.battery level
2.stamina mode remaining time
To reset stamina mode,do this:disable stamina mode,go to settings-apps-all-eco mode controller,force stop and clear data.Restart your phone and enable stamina again.
thanx bro
but do i have to do this every time ?????
No,just sometimes it understands a faster way of draining battery and it stays like that.
could you pleae forword this to tech. team as every time doing force stop and restarting phone doen't make sance
You should contact xperia care and tell them:
http://www.sonymobile.com/global-en/support/contact-us/
