First for all, sorry for my English. When update to ISC the push nofitication only work with wifi connection, when connect the data connection the push notification don't work.
Any help for me?
Check that you're using the correct APN settings with your network operator. If it still won't work it might be worth trying using another SIM card.
I talk with my operator, when i get the correct apn test it. But i have a internet connexion, despite you think this?
(Again, sorry for my english)
I configurate the apn as operator said and the push notification now found!..
thank you!
