Im bought xperia S.told to charge 4hours.im plug the phone to the charger.top of the fon red color buld on only,is it charging
KMadhuranga yes it's normal.
When you'll press the power key again the charging icond would appear, at that time, press and hold the power key and your device will turn on
Hi
Is it dark red or kinda orange ?
Switch on your phone and then try to charge it
ohh now i saw when i press on swith then charging icon appear,is it normal,this is my first time charging the fon,i press the on button then appears the charging icon,after few seconds no icon on the screen just red led on,is it normal,,
yeh phone is turn on,im not charging when the fon on,iv just turn off the fon and charg,normalyy when charging other fons appear a charging icon,on this fon no icon appears just red led light only,when i m press power key then appears the icon,,do i have to press the power key to check the charging level.
At the same time im take this time to thank u for replying quickly,thank you very much.this is my first android fon,im still new to android,thnkz again
KMadhuranga Hehe, don't worry.
Soon you would be a master in addroid
Charge your phone when it's on. Do not turn it off and charge.
Turn it on and then check the battery %.
Go to settings > phone status > there you'll see charging and battery%
thankz bro,your explanation was really helped me,sry for bother u,thnkz again, im realy confused wit samsung s2 or xperia S,now i know xperia is best....
Haha
No problem at all. Feel free to ask anything
and yess, Xperias are the best
