Hello Users of Xperia mini pro.. any idea what had happen to my phone? i cant see anything on my screen.. any help?
if you get it to get the LED to turn on when you connect it to your computer then use SUS to repair it
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Don't forget to mark theCorrect Answers & Helpful Answers
did you dropped it? did you spilled water on it?
umm.. I think I dropped it last time..spilled water not so sure.. maybe yes...my hand was wet lil bit. any idea how can i recover it? B4 this the screen was working but must play around with the slide, but now totally gone.. Ive tried to slide up n down.. nthg happen..
btw thanx for rplying..
if it was really wet then you should've put it inside a plastic bag filled with uncooked rice, does it vibrate? does it turn on (not the screen but the phone)? if it does, try to unlock it, does it vibrate?
does it charge when you connect it to the wall charger?
nope.. its not fully wet.. yup the phone vibrate. yes the phone is turn on. only that the screen only blank. ysterday the phone can charge, but today theres no orange light when charge.. umm..
Yes.. it light up when i connect to the computer.. theres orange LED on my phone.. so i need to download the SOS .. okay.. i try..
sorry. SUS*
Let us know if it works
uliwooly, its still the same... nthg happen to my phone.. still blank.. totally blakc..
not working. but the phone is ON. only that the screen is blank.
