Hello,
I just bought a new xperia U phone for my birthday. I'm really happy with this product but there is an anoying problem. I can't sync my phone with media go. It just can't detect it.
I mean with PC Compagnion, there is no problem. But when I launch Media GO. There is nothing that's detected. No phone, I can only make new playlists on the right bottom of the page.
Someone got a solution for it? P
re-install Media go and install SUS
after that run SUS and attempt to update your phone so it will look for your phone's drivers
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Media Go takes too long to transfer songs/movies
how about this
My Phone Explorer
https://play.google.com/store/apps/details?id=com.fjsoft.myphoneexplorer.client&hl=en
this app looks really cool. It helps me a lot.
But can we use podcasts on it? That's the main reason why I use Media Go.
I haven't tried it, but there's only one way to find out
give it a shot
someone found a solution?
works now, thanks a lot
Excellent
Hi , I am having some problems while connecting the PC , the phone memory card reflects as Camera and all the folders displayed in Thumbnail format and even i cant paste any pictures or files into the memory
did you tried the suggestions above?
Don't forget to mark theCorrect Answers & Helpful Answers
