Help please. Has started on phone game — has hanged, has clamped the button of inclusion and a loudness swing up — has rebooted allegedly. Now phone turns on the inscription on the sony screen is visible. Seconds five this inscription on the display and phone is switched off. What to do? With service could not help
connect it to the wall charger > press and hold the power button & volume up for 5 - 7 seconds > let it charge for an hour or so
unrelated topic, if you have some time please check this thread
Try and charge the phone for an your and restart again. Else repair your phone using SUS.
doesn't help
doesn't help
you have to take it to a Sony repair center
