Hi Sony,
I am having some difficulties with my Walkman player. When I plug in my earphones first then I open my Walkman player and play a music the sound comes out at the speaker first. I need to disconnect then plug in again my earphones so I can hear the music thru my earphones. Another problem is that when I lock my screen (by pressing the power button) the music stops when the earphone plug turns either to the left or right for just a little bit. Reason why I notice that is when I lock my phone and when I put my phone in my pocket the plug of my earphone turns so it could fit my pocket. I don't remove the plug so the music should not stop so suddenly. I'm not sure if I'm the only one experiencing this since I haven't read this issue in the forums. I already tried to repair the ICS with factory reset and setting reset with no avail. This could be a bug to be address in the next update. Hope to hear from you.
Thanks
check if there's any dust in the 3.5mm jack, I had a similar issue, and the problem was dust.
unrelated topic, if you have some time please check this thread
Hey man thanks..I just cleaned the plug and blew the hole and made sure it is connected properly and it worked..
Anytime
